MAX14581数据手册
消耗积分:0 | 格式:pdf | 大小:819 KB | 2012-07-27
分享资料个
The MAX14581/MAX14582 USB-compliant transceiversare designed to minimize the area and external componentsrequired to interface low-voltage ASICs to USB.
These devices comply with USB 2.0 specification for fullspeed-only (12Mbps) operation. The transceivers includean internal 3.3V regulator, an internal 1.5kI D+ pullupresistor, and built-in ±15kV ESD HBM protection circuitryto protect the USB I/O ports (D+, D-). The MAX14581/MAX14582 also have internal series resistors, allowing thedevices to be wired directly to a USB connector.
评论(1)
发评论
9iloveyou 2013-04-28
0 回复 举报
不错的资料。谢谢楼主 收起回复
下载排行榜
全部1条评论
