The MAX2691 low-noise amplifier (LNA) is designed forGPS L2 applications. Designed in Maxim’s advancedSiGe process, the device achieves high gain andlow noise figure while maximizing the input-referred 1dBcompression point and the 3rd-order intercept point. TheMAX2691 provides a high gain of 17.5dB and sub 1dBnoise figure.
The device operates from a +1.6V to +3.6V single supply.
The optional shutdown feature in the device reducesthe typical supply current to 4FA. The device is availablein a very small, lead-free, RoHS-compliant, 0.86mm x0.86mm x 0.65mm wafer-level package (WLP).
