The MAX4896 8-channel relay and load driver isdesigned for medium voltage applications up to 50V.This device is offered in a 20-pin, 5mm x 5mm TQFNpackage, resulting in substantial board space savings.The MAX4896 8-channel relay driver offers built-ininductive kickback protection, drive for latching/
nonlatching or dual-coil relays, and open-load andshort-circuit fault detection.The MAX4896 also protectsagainst overcurrent conditions. Each independentopen-drain output features a 3Ω (typ) on-resistance,and is guaranteed to sink 200mA of load current(VS ≥ 4.5V).
