MAX6501, MAX6502, MAX6503, MAX6504,pdf,datasheet
The MAX6501–MAX6504 low-cost, fully integrated temperature switches assert a logic signal when their die temperature crosses a factory-programmed threshold. Operating from a +2.7V to +5.5V supply, these devices feature two on-chip, temperature-dependent voltage
references and a comparator. They are available with factory-trimmed temperature trip thresholds from -45°C to +125°C in 10°C increments, and are accurate to
±0.5°C (typ) or ±6°C (max). These devices require no external components and typically consume 30μA supply current. Hysteresis is pin-selectable at +2°C or +10°C.The MAX6501/MAX6503 have an active-low, open-drain output intended to interface with a microprocessor (μP) reset input. The MAX6502/MAX6504 have an activehigh, push-pull output intended to directly drive fancontrol logic. The MAX6501/MAX6502 are offered with hot-temperature thresholds (+35°C to +125°C), asserting when the temperature is above the threshold. The MAX6503/MAX6504 are offered with cold-temperature thresholds (-45°C to +15°C), asserting when the temperature is below the threshold.The MAX6501–MAX6504 are offered in eight standard
temperature versions; contact the factory for pricing and availability of nonstandard temperature versions.They are available in 5-pin SOT23 and 7-pin TO-220 packages.
