MAX8891,MAX8892,pdf datasheet
消耗积分:0 | 格式:pdf | 大小:255 KB | 2013-01-08
分享资料个
The MAX8891/MAX8892 low-dropout (LDO) linear regulatorsare designed to deliver up to 150mA continuousoutput current. These regulators achieve a low 120mVdropout for 120mA load current.
The MAX8891 only requires an input/output capacitor,hence achieving the smallest PCB area. TheMAX8892’s output voltage can be adjusted with anexternal divider.
评论(0)
发评论
下载排行榜
