The MAX13253 is a 1A, push-pull, transformer driverdesigned to provide a simple solution for low-EMI isolatedpower supplies. The MAX13253 has an internal oscillatorand operates from a single +3.0V to +5.5V supply. Thetransformer’s secondary-to-primary winding ratio definesthe output voltage, allowing selection of virtually any isolatedoutput voltage with galvanic isolation.
