MAX16990,MAX16992数据资料
消耗积分:0 | 格式:pdf | 大小:1.16 MB | 2013-04-03
分享资料个
The MAX16990/MAX16992 are high-performance, currentmodePWM controllers with 4FA (typ) shutdown currentfor wide input voltage range boost/SEPIC converters. The4.5V to 36V input operating voltage range makes thesedevices ideal in automotive applications such as for frontend“preboost” or “SEPIC” power supplies and for the firstboost stage in high-power LED lighting applications. Aninternal low-dropout regulator (PVL regulator) with a 5Voutput voltage enables the MAX16990/MAX16992 to operatedirectly from an automotive battery input. The inputoperating range can be extended to as low as 2.5V whenthe converter output is applied to the SUP input.
评论(0)
发评论
下载排行榜
