新型高性能红外二氧化碳传感器
消耗积分:5 | 格式:rar | 大小:229 | 2009-07-07
分享资料个
介绍了红外二氧化碳传感机理,提出了一种新型空间双光束测量结构,并基于RBF 神经
网络建立了传感器数学模型。为了提高传感器动态特性,设计了动态补偿滤波器,研制成功一种新型高性能传感器。实验结果表明,上述技术有效地提高了传感器的精度、实时性及可靠性。
关 键 词:   红外;  二氧化碳传感器;  数学模型;  RBF 神经网络;  动态补偿滤波器
Abstract : The principle of sensing of carbon dioxide using IR radiation is int roduced and a novel double2beam optical st ructure is presented in the paper. Based on the good abilities of RBF network such as nonlinear mapping , learning and generalizing , the mathematic model of IR carbon dioxide sen2 sor is established. A dynamic compensation filter is designed to improve the dynamic characteristic of IR carbon dioxide sensor. A novel IR carbon dioxide sensor with high performance is made. The ex2 perimental result s show that the above key techniques prompt the accuracy , real2time and reliability of IR carbon dioxide sensor efficiently.
Key words :   IR ;  Carbon dioxide sensor ;  Mathematic model ;  RBF neural network ;   Dynamic compensation filter
评论(0)
发评论
下载排行榜
