【Atmel】ATA6623C:带有高集成稳压器的LIN总线收发器
消耗积分:0 | 格式:pdf | 大小:791KB | 2014-10-16
孔令双
分享资料个
  The Atmel® ATA6623C/ATA6625C is a fully integrated LIN transceiver,designed according to the LIN specification 2.0 and 2.1,with a low-drop voltage regulator (3.3V/5V/85mA)。The combination of voltage regulator and bus transceiver makes it possible to develop simple,but powerful,slave nodes in LIN Bus systems. The Atmel ATA6623C/ATA6625C is designed to handle the low-speed data communication in vehicles (for example,in convenience electronics)。Improved slope control at the LIN driver ensures secure data communication up to 20kBaud with an RC oscillator for the protocol handling. The bus output is designed to withstand high voltage. Sleep mode (voltage regulator switched off) and silent mode (communication off; VCC voltage on) guarantee minimized current consumption.
评论(0)
发评论
下载排行榜
