High-Voltage, High-Current OPERATIONAL AMPLIFIER OPA549
消耗积分:3 | 格式:pdf | 大小:441KB | 2015-01-10
苹果
分享资料个
The OPA549 is a low-cost, high-voltage/high-current operational amplifier ideal for driving a wide variety of loads。 This laser-trimmed monolithic integrated circuit provides excellent low-level signal accuracy and high output voltage and current。The OPA549 operates from either single or dual supplies for design flexibility。The input common-mode range extends below the negative supply。
评论(0)
发评论
下载排行榜
