LTC1735数据手册
消耗积分:0 | 格式:pdf | 大小:375KB | 2015-10-20
分享资料个
The LTC® 1735 is a synchronous step-down switching regulator controller that drives external N-channel power MOSFETs using a fixed frequency architecture. Burst ModeTM operation provides high efficiency at low load currents. The precision 0.8V reference is compatible with future microprocessor generations. OPTI-LOOP compensation allows the transient response to be optimized over a wide range of output capacitance and ESR values.
评论(0)
发评论
下载排行榜
