ADC Convertor Using the MAX 10 FPGA Development Kit
消耗积分:0 | 格式:pdf | 大小:657KB | 2015-12-06
jinyi7016
分享资料个
10M50DA device has two analog-to-digital converters (ADC) which can be used to monitor the internal temperature of the die and support external analog signal conversion. So this design example is used to check out FPGA embedded ADC components alongside with external DAC and potentiometer on the board.
评论(0)
发评论
下载排行榜
