L293D_L293DD_PUSH-PULL_FOUR_CHANNEL_DRIVER_WITH_DIODES
消耗积分:1 | 格式:pdf | 大小:497KB | 2016-01-17
wkeqian
分享资料个
The Device is a monolithic integrated high voltage, high current four channel driver designed to accept standard DTL or TTL logic levels and drive inductive loads (such as relays solenoides, DC and stepping motors) and switching power transistors.
评论(0)
发评论
下载排行榜
