SMD602,pdf datasheet (two term
消耗积分:10 | 格式:rar | 大小:433 | 2009-08-26
王璐
分享资料个
The SMD602 is a two terminal LED protector with
low dropout voltage rated for 500mA bypass
current. Low operation current at protection mode
and high bypass current capability at activating
mode. Build-in reverse diode for bypass reversed
supply voltage.
The SMD602 is designed for parallel connection
with power LED. It bypasses LED driving current
when LED at open circuit condition. It also
bypasses LED driving current at reverse connected
driving current to LED.
评论(2)
发评论
jiangheng 2019-03-14
0 回复 举报
很实用,谢谢分享! 收起回复
topzzm 2011-06-07
2 回复 举报
GOOD!!!!!! 收起回复
下载排行榜
全部2条评论
