TDA1514/TDA1514A,pdf,datasheet
消耗积分:10 | 格式:rar | 大小:322 | 2009-09-17
分享资料个
The TDA1514A integrated circuit is a hi-fi power amplifier for use as a building block in radio, tv and other audio applications. The high performance of the IC meets the requirements of digital sources (e.g. Compact Disc equipment).The circuit is totally protected, the two output transistors both having thermal and SOAR protection (see Fig.3). The circuit also has a mute function that can be arranged for a period after power-on with a delay time fixed by external components.The device is intended for symmetrical power supplies but an asymmetrical supply may also be used.
评论(0)
发评论
下载排行榜
