LPV511,pdf datasheet (Micropow
消耗积分:2 | 格式:rar | 大小:555 | 2009-10-08
20615
分享资料个
The LPV511 is a micropower operational amplifier that operates
from a voltage supply range as wide as 2.7V to 12V with
guaranteed specifications at 3V, 5V and 12V. The LPV511
exhibits an excellent speed to power ratio, drawing only 880
nA of supply current with a bandwidth of 27 kHz. These specifications
make the LPV511 an ideal choice for battery powered
systems that require long life through low supply current,
such as instrumentation, sensor conditioning and battery current
monitoring.
评论(0)
发评论
下载排行榜
