LM98519,pdf datasheet (10-bit
消耗积分:2 | 格式:rar | 大小:551 | 2009-10-12
学电超人
分享资料个
The LM98519 is a fully integrated, high performance 10-Bit,
65 MSPS signal processing solution for digital color copiers,
scanners, and other image processing applications. Highspeed
signal throughput is achieved with an innovative six
channel architecture utilizing Correlated Double Sampling
(CDS), or Sample and Hold (SH) type sampling. 1x or 2x gain
settings are available in the CDS/SH input stage. Each channel
has a dedicated 1x to 10x (8 bit) PGA that allows accurate
gain adjustment of each channel. The Digital White Level auto
calibration loop can automatically set the PGA value to
achieve a selected white target level. Each channel also has
a ±4 bit coarse and ±10-bit fine analog offset correction DAC
that allows offset correction before the sample-and-hold amplifier.
These correction values can be controlled by an automated
Digital Black Level correction loop. The PGA and offset
DACs for each channel are programmed independently allowing
unique values of gain and offset for each of the six
channels. A 2-to-1 multiplexing scheme routes the signals to
three 65MHz high performance ADCs. The fully differential
processing channels achieve exceptional noise immunity,
having a very low noise floor of -68dB. The 10-bit analog-todigital
converters have excellent dynamic performance making
the LM98519 transparent in the image reproduction chain.
评论(0)
发评论
下载排行榜
