LM56,datasheet,pdf(Dual Output
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-20
分享资料个
The LM56 is a precision low power thermostat. Two stable
temperature trip points (VT1 and VT2) are generated by dividing
down the LM56 1.250V bandgap voltage reference using
3 external resistors. The LM56 has two digital outputs. OUT1
goes LOW when the temperature exceeds T1 and goes HIGH
when the the temperature goes below (T1–THYST). Similarly,
OUT2 goes LOW when the temperature exceeds T2 and goes
HIGH when the temperature goes below (T2–THYST). THYST is
an internally set 5°C typical hysteresis.
评论(0)
发评论
下载排行榜
