1 FEATURES • Requires very few external components • High output power • Low output offset voltage Bridge-Tied Load (BTL) channel • Fixed gain • Good ripple rejection • Mode select switch: operating, mute and standby • Short-circuit safe to ground and across load • Low power dissipation in any short-circuit condition • Thermally protected • Reverse polarity safe • Electrostatic discharge protection • No switch-on and switch-off plops • Flexible leads • Low thermal resistance • Identical inputs: inverting and non-inverting. 2 APPLICATIONS • Multimedia systems • Active speaker systems (stereo with sub woofer or QUAD). 3 GENERAL DESCRIPTION The TDA8512J is an integrated class-B output amplifier in a 17-lead Single-In-Line (SIL) power package. It contains 4 × 13 WSingle Ended (SE) amplifiers of which two can be used to configure a 26 W BTL amplifier.
