通过感知物体的碰撞来保持设备的健康
远程监测传感器数据使企业能够保护他们的底线,从检测未经授权的篡改与远程安装的资产,以确定第一个迹象表明,制造设备需要调整。振动传感可以提供有价值的情报在任一角色,无论是简单地触发报警或使机械磨损详细分析。
许多技术是可行的振动监测。一个低成本的阈值传感器可以创建简单地绕一个弹簧围绕一个金属销。当暴露于振动时,弹簧接触销并关闭开关。另一方面,多轴MEMS运动传感器具有宽的带宽和宽的动态范围,适合用于监测机器健康。
Basic Theft Prevention
A simple tamper detector can be built using low-cost hardware such as the MikroElektronika Vibra Sense click board, which contains a simple threshold sensor. The board has a digital output, which is capable of indicating the intensity of the vibrations detected and can be set as an interrupt. An on-board potentiometer enables the user to adjust the interrupt threshold. The Vibra Sense board provides a cost-efficient means of implementing an anti-tamper or anti-theft mechanism capable of initiating a response to events such as tilting of a gaming or vending machine, or attempts to remove almost any type of unsupervised, networked equipment. This could include equipment installed outdoors, such as traffic counters, air-quality monitors, weather recorders, or any other appliances used for remote monitoring.
The Vibra Sense sensor connects directly to an embedded processor board via standard MikroBus headers. A wide variety of MikroElektronika computing boards are available, based on well-known microcontrollers from manufacturers such as Atmel, Cypress, Microchip, NXP,STMicroelectronics, and Texas Instruments. Code examples for all MikroElektronika compilers are available from MikroElektronika’s Libstock
