TDA8932/TDA8932B pdf datasheet
消耗积分:10 | 格式:rar | 大小:777 | 2008-07-16
张国厚
分享资料个
1. General description
The TDA8932B is a high efficiency class-D amplifier with low power dissipation.
The continuous time output power is 2 × 15 W in stereo half-bridge application (RL =4 Ω)
or 1 × 30 W in mono full-bridge application (RL =8 Ω). Due to the low power dissipation
the device can be used without any external heat sink when playing music. Due to the
implementation of thermal foldback, even for high supply voltages and/or lower load
impedances, the device remains operating with considerable music output power without
the need for an external heat sink.
The device has two full-differential inputs driving two independent outputs. It can be used
as mono full-bridge configuration (BTL) or as stereo half-bridge configuration (SE).
2. Features
n Operating voltage from 10 V to 36 V asymmetrical or ±5 V to ±18 V symmetrical
n Mono-bridged tied load (full-bridge) or stereo single-ended (half-bridge) application
n Application without heatsink using thermally enhanced small outline package
n High efficiency and low-power dissipation
n Thermally protected and thermal foldback
n Current limiting to avoid audio holes
n Full short-circuit proof across load and to supply lines (using advanced current
protection)
n Switchable internal or external oscillator (master-slave setting)
n No pop noise
n Full-differential inputs
3. Applications
n Flat panel television sets
n Flat panel monitor sets
n Multimedia systems
n Wireless speakers
n Mini and micro systems
n Home sound sets
评论(0)
发评论
下载排行榜
