用于串行传感器系统的开发和评估板
当传感器接近感知时,它们的工作效果最好。距离越远,诱导噪声的水平越高,通过布线效应可以降低信号的影响。
用放大器和缓冲器增加信号强度可以使其他低电平信号的传输时间更长。在下降的方面,这可以使用更高水平的功率和辐射EMI和RFI取决于信号或电缆的特点。
另一种方法是使传感器本身成为数字子系统,并使用串行通信技术,使其能够干净、便宜地旅行。作为一个状态机或在嵌入式控制器的指导下,传感器信息的数字化意味着中央收集点可以可靠地收集分布在本地板上的数据,也可以可靠地收集空间或空间的大量数据。
This article looks at serial sensors and subsystems that we design engineers have at our disposal and some of the development and evaluation kits available to support them. It examines the transducer types available and the A/D converter subsystems used for serial transmission of typically short-reach analog data. It will discuss off-the-shelf solutions and the advantages they possess over one another. All parts, training material, data sheets, demo, evaluation and development kits mentioned here are available online at the Digi-Key website.
