MAX504/MAX515 pdf datasheet
消耗积分:5 | 格式:rar | 大小:777 | 2008-07-20
陈文博
分享资料个
The MAX504/MAX515 are low-power, voltage-output,
10-bit digital-to-analog converters (DACs) specified for
single +5V power-supply operation. The MAX504 can
also be operated with ±5V supplies. The MAX515
draws only 140μA, and the MAX504 (with internal reference)
draws only 260μA. The MAX515 comes in 8-pin
DIP and SO packages, while the MAX504 comes in 14-
pin DIP and SO packages. Both parts have been
trimmed for offset voltage, gain, and linearity, so no further
adjustment is necessary.
The MAX515’s buffer is fixed at a gain of 2. The MAX504’s
internal op amp may be configured for a gain of 1 or 2, as
well as for unipolar or bipolar output voltages. The
MAX504 can also be used as a four-quadrant multiplier
without external resistors or op amps.
For parallel data inputs, see the MAX503 data sheet.
For a hardware and software compatible 12-bit
upgrade, refer to the MAX531/MAX538/MAX539 data
sheet.
_______________________Applications
Battery-Powered Test Instruments
Digital Offset and Gain Adjustment
Battery-Operated/Remote Industrial Controls
Machine and Motion Control Devices
Cellular Telephones
评论(0)
发评论
下载排行榜
