bav199 pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-07-21
分享资料个
Low-leakage double diode BAV199
• Plastic SMD package
• Low leakage current: typ. 3 pA
• Switching time: typ. 0.8 µs
• Continuous reverse voltage:
max. 75 V
• Repetitive peak reverse voltage:
max. 85 V
• Repetitive peak forward current:
max. 500 mA.
APPLICATION
• Low-leakage current applications in
surface mounted circuits.
DESCRIPTION
Epitaxial, medium-speed switching,
double diode in a small SOT23 plastic
SMD package. The diodes are
connected in series.
评论(0)
发评论
下载排行榜
