512K×8位低功耗CMOS SRAM,AS6C4008
消耗积分:0 | 格式:rar | 大小:0.70 MB | 2017-09-19
分享资料个
  The AS6C4008 is a 4,194,304-bit low power CMOS static random access memory organized as 524,288 words by 8 bits. It is fabricated using very high performance, high reliability CMOS technology. Its standby current is stable within the range of operating temperature. The AS6C4008 is well designed for very low power system applications, and particularly well suited for battery back-up non-volatile memory application. The AS6C4008 op erates from a sing le p owe r sup p ly of 2.7V~ 5.5Vand all inputs and outputs are fully TTL compatible.
评论(0)
发评论
下载排行榜
