MM54HC253/MM74HC253 Dual 4-Channel TRI-STATEÉ Multiplexer General Description The MM54HC253/MM74HC253 utilizes advanced silicongate CMOS technology to achieve the low power consumption and high noise immunity of standard CMOS integrated circuits, along with the capability to drive 10 LS-TTL loads. The large output drive and TRI-STATE features of this device make it ideally suited for interfacing with bus lines in bus organized systems. When the output control input is taken high, the multiplexer outputs are sent into a high impedance state. When the output control is held low, the associated multiplexer chooses the correct output channel for the given input signals determined by the select A and B inputs. The 54HC/74HC logic family is functionally and pinout compatible with the standard 54LS/74LS logic family. All inputs are protected from damage due to static discharge by internal diode clamps to VCC and ground. Features Y Typical propagation delay: 24 ns Y Wide power supply range: 2V±6V Y Low quiescent current: 80 mA maximum (74HC Series) Y Low input current: 1 mA maximum Y Fanout of 10 LS-TTL loads
