MM54HC258/MM74HC258 Quad 2-Channel TRI-STATEÉ Multiplexer (Inverted Output) General Description This Quad 2-to-1 line data selector/multiplexer utilizes advanced silicon-gate CMOS technology. Along with the high noise immunity and low power dissipation of standard CMOS integrated circuits, these possess the ability to drive LS-TT loads. The large output drive capability with the TRI-STATE feature make this device ideal for interfacing with bus lines in a bus organized system. When the Output Control line is taken high, the outputs of all four multiplexers are sent into a high impedance state. When the Output Control line is low, A or B data is selected for the HC258. The 54HC/74HC logic family is speed, function, and pin-out compatible with the standard 54LS/74LS logic family. All inputs are protected from damage due to static discharge by internal diode clamps to VCC and ground. Features Y Typical propagation delays: 16 ns Y Wide power supply range: 2V±6V Y Low quiescent supply current: 80 mA maximum (74HC Series) Y TRI-STATE outputs for connection to system buses Y Added circuitry allows data input levels to float during TRI-STATE with no additional power consumption
