MC34672,pdf datasheet (2.0 A N
消耗积分:5 | 格式:rar | 大小:444 | 2010-01-12
吴湛
分享资料个
The MC34672 is a highly integrated - 48 V hot swap controller with an internal Power MOSFET. It provides the means to safely install and remove boards from live - 48 V backplanes without having to power down the entire system. It regulates the inrush current, from the supply to the load’s filter capacitor, to a user-programmable limit, allowing the system to safely stabilize. A disable function allows the user to disable the 34652 manually or through a microprocessor and safely disconnect the load from the main power line.
The 34652 has active high and active low power good output signals that can be used to directly enable a power module load. Programmable under- and overvoltage detection circuitry monitors the input voltage to check that it is within its operating range. A programmable start-up delay timer ensures that it is safe to turn on the Power MOSFET and charge the load capacitor.
A two-level current limit approach to controlling the inrush current and switching on the load limits the peak power dissipation in the Power MOSFET. Both current limits are user programmable.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
