74LS114/54LS114 pdf datasheet
消耗积分:3 | 格式:rar | 大小:133 | 2008-08-06
fansz
分享资料个
54LS114
Dual JK Negative Edge-Triggered
Flip-Flop with Common Clocks and Clears
General Description
The 'LS114 features individual J, K and set inputs and common
clock and common clear inputs. When the clock goes
HIGH the inputs are enabled and data will be accepted. The
logic level of the J and K inputs may be allowed to change
when the Clock Pulse is HIGH and the bistable will perform
according to the truth table as long as the minimum setup
times are observed. Input data is transferred to the outputs
on the negative-going edge of the clock pulse.
评论(0)
发评论
下载排行榜
