EUP3270升级版HSW-EUP3271A最大可做4.8A,用于车充,多口充,无线充参数介绍
消耗积分:0 | 格式:pdf | 大小:369.61 KB | 2025-07-24
深圳市华升微电子有限公司
  • 56内容
  • 4.1w阅读
  • 82粉丝
EUP3271A-CC/CV Synchronous Step-Down Converter
DESCRIPTION
  The EUP3271A is a synchronous step-down convertercapable of driving
5A continuous load with excellentline and load regulation.
The EUP3271A operates ineither CC (Constant Current) mode or
CV (Constant Voltage) mode with an input voltage range from 4.5Vto 36V.
The EUP3271A provides programmable cablecompensation by adjusting external resistor divider.
External shutdown function can be controlled bypulling COMP pin to a level below 0.14V.
Fault protection includes secondary cycle-by-cyclecurrent limit, short circuit protection and thermalshutdown.
 Internal soft-start minimizes the inrushsupply current and the output overshoot at initialstartup.
The EUP3271A is available in 5mm×5mm TQFN-20package.
FEATURES
4.5V to 36V Wide Input Operating Range
80kHz~400kHz Switching Frequency Selection
CC/CV Mode Control
Up to 5A Output Current
+/- 1.5% Voltage Reference Accuracy
+/- 4% Constant Current Accuracy
Programmable Cable Compensation
Internal Soft Start
Single Pin to External Compensation andShutdown Control
Hiccup Short Circuit Protection
Secondary Cycle-by-Cycle Current Limit
Thermal Shutdown
Available in 5mm×5mm TQFN-20 Package
RoHS Compliant and100% Lead(Pb)-FreeHalogen-Free
APPLICATIONS
Car Charger
Portable charger applications
DC/DC converters with current limited
评论(0)
发评论
下载排行榜
