MC33030,pdf,monolithic DC serv
消耗积分:10 | 格式:rar | 大小:344 | 2010-02-27
李鸿洋
分享资料个
The MC33030 is a monolithic DC servo motor controller providing
all active functions necessary for a complete closed loop system. This
device consists of an on–chip op amp and window comparator with
wide input common–mode range, drive and brake logic with direction
memory, Power H–Switch driver capable of 1.0 A, independently
programmable over–current monitor and shutdown delay, and
over–voltage monitor. This part is ideally suited for almost any servo
positioning application that requires sensing of temperature, pressure,
light, magnetic flux, or any other means that can be converted to a
voltage.
评论(0)
发评论
下载排行榜
