CAT3200 CAT3200-5低噪声可调电荷泵转换器数据
消耗积分:2 | 格式:rar | 大小:221 | 2010-03-04
分享资料个
The CAT3200 and CAT3200-5 are switched capacitor boost converters that deliver a low noise, regulated output voltage. The CAT3200-5 gives a fixed regulated 5V output. The CAT3200 has an adjustable output using external resistors. The constant frequency 2MHz
charge pump allows small 1μF ceramic capacitors to be used.
评论(0)
发评论
下载排行榜
