The EMD2794/EMD2795 is a 1.5x/1.0x charge pump that provides four regulated current sources. It accepts an input voltage range from 2.7V to 5.5V and maintains a constant current determined by an external resistor. The EMD2794/EMD2795 delivers up to 80mA of load current to accommodate four White LEDs. The switching frequency is fixed at 1.2MHz to make noise filtering easier. Brightness control can be done by both linear and PWM techniques. Linear control is achieved by applying 0V to 3.0V to the BRGT pin to linearly vary the LED current. PWM technique is to apply a clock to the EN pin to having brightness varying with clock duty. Shutdown is done by applying low (high for 2795) to the pin EN. The VIN current drops to less than 1.0uA in shutdown mode. The EMD2794/EMD2795 is available in a TQFN-16 & FBP-16 3x3 package.
