SD2315磁编器芯片分辨率配置程序
消耗积分:0 | 格式:zip | 大小:1.61 KB | 2025-12-23
璟逸电子
  • 31内容
  • 3.4w阅读
  • 8粉丝
void SD2315_ResoluReg_Set(void) {  uint16_t Num0=0;  /****** 分辨率设置 ******/  Num0=2000;  //设置分辨率的值  SD2315_Write_Reg(0x31,Num0&0xFF);  SD2315_Write_Reg(0x32,(Num0>>8)&0xFF);  SD2315_Write_Reg(0x20,0xB3);  //解锁OTP  SD2315_Write_Reg(0x11,SD2315_OTP_PAGE5);  //写入页码Page5  SD2315_Write_Reg(0x10,0x02);  //OTP编程指令(后需等待延时)  delay_ms(500);  SD2315_Write_Reg(0x11,SD2315_OTP_PAGE5);  //再次写入页码Page5  SD2315_Write_Reg(0x20,0xB3);  //解锁OTP  SD2315_Write_Reg(0x10,0x12);  //OTP编程指令编写页码  SD2315_Write_Reg(0x20,0x00);  //OTP锁定 }
评论(0)
发评论
下载排行榜
