VSP2254,pdf(VSP2254: 36-MHz Sa
消耗积分:3 | 格式:rar | 大小:307 | 2010-06-12
从未拥有
分享资料个
The VSP2254 is a high-speed and high-resolution mixed-signal processing IC for CCD signal processing, which integrates two channels of correlated double sampling (CDS) and a 14-bit analog-to-digital converter. The VSP2254 also provides black level clamping for an accurate black level reference, input signal clamping, and offset correction of the CDS. The VSP2254 operates from 2.7 V to 3.6 V of single supply.
评论(0)
发评论
下载排行榜
