AFE8405,pdf(14-bit, 85-MSPS AD
消耗积分:3 | 格式:rar | 大小:3000 | 2010-07-08
听风说梦
分享资料个
The AFE8405 is a multichannel communications signal processor that provides analog-to-digital conversion and digital downconversion optimized for cellular base transceiver systems. The device supports UMTS, CDMA-1X, and TD-SCDMA air-interface cellular standards.
The AFE8405 provides up to 8 UMTS digital downconverter channels (DDC), 16 CDMA DDCs or 16 TD-SCDMA DDCs. The DDC channels are independent and operate simultaneously.
The AFE8405 DDCs have three input ports; one is hardwired to the internal 14-bit analog-to-digital converter (rxin_a) and two are 16-bit digital inputs (rxin_c, rxin_d). Each DDC channel can be programmed to accept data from any one of the three input ports; rxin_b is not used.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
