The Cypress CY2 series of network circuits is produced using
advanced 0.35-micron CMOS technology, achieving the
industry’s fastest logic.
The Cypress CY2DL814 fanout buffer features a single
LVDS-, LVPECL-, or LVTTL-compatible input and four LVDS
output pairs.
Designed for data-communication clock management applications,
the fanout from a single input reduces loading on the
input clock.
The CY2DL814 is ideal for both level translations from single
ended to LVDS and/or for the distribution of LVDS-based clock
signals. The Cypress CY2DL814 has configurable input and
output functions. The input can be selectable for
LVPECL/LVTTL or LVDS signals while the output driver’s
support standard and high drive LVDS. Drive either a 50-ohm
or 100-ohm line with a single part number/device.
Features
• Low-voltage operation
• VDD = 3.3V
• 1:4 Fanout
• Single-input configurable for
—LVDS, LVPECL, or LVTTL
—Four differential pairs of LVDS outputs
• Drives 50- or 100-ohm load (selectable)
• Low input capacitance
• Low output skew
• Does not exceed Bellcore 802.3 standards
• Operation at ⇒ 350 MHz – 700 Mbps
• Low propagation delay Typical (tpd < 4 ns)
• Industrial versions available
• Packages available include TSSOP/SOIC
