SN54AHCT16240, SN74AHCT16240,p
消耗积分:2 | 格式:rar | 大小:374 | 2010-07-11
20762
分享资料个
The 'AHCT16240 devices are 16-bit buffers and line drivers designed specifically to improve the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters.
These devices can be used as four 4-bit buffers, two 8-bit buffers, or one 16-bit buffer. They provide inverting outputs and symmetrical active-low output-enable (OE\) inputs.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
The SN54AHCT16240 is characterized for operation over the full military temperature range of -55°C to 125°C.
评论(0)
发评论
下载排行榜
