SN74AHCT126-Q1,pdf(Quadruple B
消耗积分:2 | 格式:rar | 大小:171 | 2010-07-16
杜喜喜
分享资料个
The SN74AHCT126 device is a quadruple bus buffer gate featuring independent line drivers with 3-state outputs. Each output is disabled when the associated output-enable (OE) input is low. When OE is high, the respective gate passes the data from the A input to its Y output.
To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver.
评论(0)
发评论
下载排行榜
