SN54LV244A, SN74LV244A,pdf(OCT
消耗积分:2 | 格式:rar | 大小:703 | 2010-07-19
郝埃连
分享资料个
These octal buffers/line drivers are designed for 2-V to 5.5-V VCC operation.
The ’LV244A devices are designed specifically to improve both the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters.
These devices are organized as two 4-bit line drivers with separate output-enable (OE)\ inputs. When OE\ is low, the device passes data from the A inputs to the Y outputs. When OE\ is high, the outputs are in the high-impedance state.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
评论(0)
发评论
下载排行榜
