CY74FCT162H245CT,pdf(16-Bit Tr
消耗积分:2 | 格式:rar | 大小:313 | 2010-07-23
分享资料个
These 16-bit transceivers are designed for use in bidirectional synchronous communication between two buses, where high speed and low power are required. With the exception of the CY74FCT16245T, these devices can be operated either as two independent octals or a single 16-bit transceiver. Direction of data flow is controlled by (DIR), the Output Enable (OE\) transfers data when LOW and isolates the buses when HIGH.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
The CY74FCT16245T is ideally suited for driving high-capacitance loads and low-impedance backplanes.
评论(0)
发评论
下载排行榜
