SN54AHC373, SN74AHC373,pdf(OCT
消耗积分:2 | 格式:rar | 大小:750 | 2010-07-30
王毅山
分享资料个
The ’AHC373 devices are octal transparent D-type latches designed for 2-V to 5.5-V VCCoperation.
When the latch-enable (LE) input is high, the Q outputs follow the data (D) inputs. When LE is low, the Q outputs are latched at the logic levels of the D inputs.
A buffered output-enable (OE)\ input can be used to place the eight outputs in either a normal logic state (high or low) or the high-impedance state. In the high-impedance state, the outputs neither load nor drive the bus lines significantly. The high-impedance state and increased drive provide the capability to drive bus lines without interface or pullup components.
OE\ does not affect the internal operations of the latches. Old data can be retained or new data can be entered while the outputs are in the high-impedance state.
评论(0)
发评论
下载排行榜
