CD54HC75, CD74HC75, CD54HCT75,
消耗积分:3 | 格式:rar | 大小:603 | 2010-08-03
刘洋
分享资料个
The ’HC75 and ’HCT75 are dual 2-bit bistable transparent latches. Each one of the 2-bit latches is controlled by separate Enable inputs (1E\ and 2E\) which are active LOW. When the Enable input is HIGH data enters the latch and appears at the Q output. When the Enable input (1E\ and 2E\) is LOW the output is not affected.
评论(0)
发评论
下载排行榜
