SN74HC595-EP,pdf(8-Bit Shift R
消耗积分:5 | 格式:rar | 大小:310 | 2010-08-03
分享资料个
The SN74HC595 contains an 8-bit serial-in, parallel-out shift register that feeds an 8-bit D-type storage register. The storage register has parallel 3-state outputs. Separate clocks are provided for both the shift and storage register. The shift register has a direct overriding clear (SRCLR) input, serial (SER) input, and serial outputs for cascading. When the output-enable (OE) input is high, the outputs are in the high-impedance state.
Both the shift register clock (SRCLK) and storage register clock (RCLK) are positive-edge triggered. If both clocks are connected together, the shift register always is one clock pulse ahead of the storage register.
评论(1)
发评论
linj9iang 2012-05-03
0 回复 举报
不错 收起回复
下载排行榜
全部1条评论
