SN54LV594A,SN74LV594A,pdf(8-Bi
消耗积分:2 | 格式:rar | 大小:633 | 2010-08-04
分享资料个
The ’LV594A devices are 8-bit shift registers designed for 2-V to 5.5-V VCC operation.
These devices contain an 8-bit serial-in, parallel-out shift register that feeds an 8-bit D-type storage register. Separate clocks (RCLK, SRCLK) and direct overriding clear (RCLR\, SRCLR\) inputs are provided on the shift and storage registers. A serial output (QH') is provided for cascading purposes.
The shift-register (SRCLK) and storage-register (RCLK) clocks are positive-edge triggered. If the clocks are tied together, the shift register always is one clock pulse ahead of the storage register.
评论(0)
发评论
下载排行榜
