MAX6029 pdf,MAX6029 datasheet
消耗积分:3 | 格式:rar | 大小:888 | 2008-09-11
h1708587244.0670
分享资料个
The MAX6029 micropower, low-dropout bandgap voltage
reference combines ultra-low supply current and
low drift in a miniature 5-pin SOT23 surface-mount package
that uses 70% less board space than comparable
devices in an SO package. An initial accuracy of 0.15%
and a 30ppm/°C (max) temperature coefficient make the
MAX6029 suitable for precision applications. This
series-mode voltage reference sources up to 4mA and
sinks up to 1mA of load current. A wide 2.5V to 12.6V
supply range, ultra-low 5.25μA (max) supply current,
and a low 200mV dropout voltage make these devices
ideal for battery-operated systems. Additionally, an
internal compensation capacitor eliminates the need for
an external compensation capacitor and ensures stability
with load capacitances up to 10μF.
The MAX6029 provides six output voltages of 2.048V,
2.5V, 3V, 3.3V, 4.096V, and 5V. The MAX6029 is available
in a 5-pin SOT23 or an 8-pin SO package and is
specified over the extended temperature range (-40°C
to +85°C).
Applications
Battery-Powered Systems
Hand-Held Instruments
Precision Power Supplies
A/D and D/A Converters
评论(0)
发评论
下载排行榜
