SN74AHC4066,PDF(QUADRUPLE BILA
消耗积分:5 | 格式:rar | 大小:797 | 2010-08-13
贾小龙
分享资料个
This quadruple silicon-gate CMOS analog switch is designed for 2-V to 5.5-V VCC operation.
This switch is designed to handle both analog and digital signals. Each switch permits signals with amplitudes up to 5.5 V (peak) to be transmitted in either direction.
Each switch section has its own enable-input control (C). A high-level voltage applied to C turns on the associated switch section.
Applications include signal gating, chopping, modulation or demodulation (modem), and signal multiplexing for analog-to-digital and digital-to-analog conversion systems.
评论(0)
发评论
下载排行榜
