ONET4211LD,pdf(155 Mbps to 4.2
消耗积分:2 | 格式:rar | 大小:769 | 2010-08-28
分享资料个
The ONET4211LD is a laser driver for multiple fiber optic applications up to 4.25 Gbps. The device accepts CML input data and provides bias and modulation currents for driving a laser diode. Also provided are automatic power control (APC), temperature compensation of modulation current, fault detection, and current monitor features.
The device is available in a small-footprint, 4 mm × 4 mm 24-pin QFN package. The circuit requires a single 3.3-V supply.
This power-efficient laser driver is characterized for operation from -40°C to 85°C.
评论(0)
发评论
下载排行榜
