TRS208,pdf(5-V MULTICHANNEL RS
消耗积分:2 | 格式:rar | 大小:449 | 2010-08-31
李伟
分享资料个
The TRS208 device consists of four line drivers, four line receivers, and a dual charge-pump circuit with ±15-kV HBM ESD protection pin to pin (serial-port connection pins, including GND). The device meets the requirements of TIA/EIA-232-F and provides the electrical interface between an asynchronous communication controller and the serial-port connector. The charge pump and four small external capacitors allow operation from a single 5-V supply. The devices operate at data signaling rates up to 120 kbit/s and a maximum of 30-V/µs driver output slew rate.
评论(0)
发评论
下载排行榜
