MAX3238-Q1,pdf(3-V to 5.5V Mul
消耗积分:3 | 格式:rar | 大小:237 | 2010-09-02
ejlwj
分享资料个
The MAX3238 consists of five line drivers, three line receivers, and a dual charge-pump circuit with ±15-kV ESD (HBM) protection pin to pin (serial-port connection pins, including GND). The device meets the requirements of TIA/EIA-232-F and provides the electrical interface between notebook and subnotebook computer applications. The charge pump and four small external capacitors allow operation from a single 3-V to 5.5-V supply. In addition, the device includes an always-active noninverting output (ROUT1B), which allows applications using the ring indicator to transmit data while the device is powered down. These devices operate at data signaling rates up to 250 kbit/s and a maximum of 30-V/µs driver output slew rate.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
